Permabanned
- 7 Jul 2005
- Suffolk
I have been trying to setup a network to my fathers pc so i can use his badass printer but cant work out how to connect.
I have setup networks before and normaly get thru it easily<edit, but for some reason, when i try to connect either through the router or through the adress bar. It doesnt connect
Thing is i can connect to my pc from my dads
i have changed the network name to the same on both pc's
tried disabling firewalls
tried changing aload of the router settings.
anyone have any suggestions? thanx
