I posted a while ago about setting up a network http://forums.overclockers.co.uk/showthread.php?t=17617736. Today i've been trying to set it up. I have the parts listed in that post. I have successfully connected via this machine (on ethernet PCI adapter thing) and via my machine (via USB wireless adapter). There are of course problems though. Most significantly, this computer. It is incredibly laggy now, all the time. These words are appearing late and the mouse movement is jerky, it is nearly unusable tbh. I have no idea why this is
. Also, on my computer, whenever I send information (ie, entering text on google) it comes up with "you are sending over an unencrypted network", even though I have 64bit encryption enabled and it even says so on the connection information in my system tray? WTF. This machine is laggy even with mine off and unconnected btw. Any help appreciated
, yeah, I will check the drivers, i'm not sure if the installation did finish entirely. At the moment, it is fine, I have a feeling it goes wierd when I connect to it with mine aswell but will check for sure. Task manager shows the GA311 card running, and it has an icon in system tray.
. The instruction set never clearly said to, but I've noticed the CD now. I will redo the setup now I think. Is that also likely to be why the encryption didn't work?
. Is there a specific password I need (though I can't figure out why it's asking for one anyhow)
