- 18 Oct 2002
- At home
Hi,
Strange issue, since building my file server when transferring files between when the two pc's are on the same switch I get about 40 - 50 mb/sec which seems fine for a gb network.
However when I transfer files downstairs which goes through another gb switch first the transfer rate drops to about 10 - 15 mb/sec
Any reason why this might be ?
The switch upstairs is a netgear 5 port gb switch with a 10gbps backbone
The switch downstairs is a netgear 8 port gb switch with a 16 gbps backbone.
when I did the test no other machines were on.
Thanks,
Thanks,
