Hi,
Moving away from consoles.... Had enough of buying a new one every couple of years. Iv looked into parts and have finally decided on what to get but I'm unsure whether to build it myself or not as iv not done this before.
This build iv planned would also use a water cooler...... Is this a good idea for a first build or is this a Disaster waiting to happen?
Thanks for reading
Kind regards
Knoqulous
Last time I checked a console lasts 5 years minimum.
If you are sick and tired of buying a new one. Then pc would be a terrible alternative.
I've bought maybe 4-6 different pcs and about 10 gpu's in the past 3 years.
Because with pcs you can always buy better parts and upgrades.
With a console it's the same system for the best part of a decade.
So what's the real issue? Also pcs cost a lot more than consoles overall.
You will already have a TV. A decent gaming monitor is expensive and if you go chasing higher res and fps it becomes at pidly expensive. My mate at work spent I think £2500 on his pc. That was for the rig only. His monitor was another £1k on top. Then it's another £250 for his keyboard and mouse.
Sure you can use a £30 keyboard and mouse but it's a slippery slope.
As for watercooling I've been building pcs for 20 years and I've never bothered with it.
It looks great. However it's stupidly expensive and either than being quiet if done right it's a pain to set up and has no great benefit in the scheme of things other than aesthetics.
My cpu and gpu run around 65c whilst gaming. The gpu will start throttling at 80c and it will be in the danger zone around 90-100c.
So makes zero sense for me to do it for temps.
Personally I find upgrading pcs a pain with lots of expensive upgrades hardly being worth the bother. Consoles are far simpler and less hassle.
