- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
OcUK are proud to be the first to offer the latest range of new Lian Li cases on pre-order. All new 2010 models that include excellent cooling performance, select models also including USB3.0 front I/O ports and all cases feature a fully tool-less design.
With stock due into us around the middle of June, get your pre-orders placed now.
Lian Li PC-8FIB Aluminium Midi Tower Case - Black @ £234.99 inc VAT
The look of PC-8FI has a minimalism style. The front panel design is a combination of art and functionality, with the hair line brushed and anodized aluminum finish to make this the ultimate high-end chassis. The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the bottom of the case is cooled with fresh cool air directly from the outside of the case, instead of pre-heated air from within. This will bring down the core temperatures and extend the lifespan of the PSU significantly. The PC-8FI is a Mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. All the internal installation can be done without tools, and is easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots this chassis can hold up to four graphics cards, supporting CrossfireX™ and 4-way SLI™.
The PC-8FI is equipped with large cooling fans, with low RPM, which still provide enough air flow to cool down the hardware adequately. The front two 120mm intakes Blue LED fan runs at 1200RPM. The rear 120mm exhaust fan just next to the CPU, it can remove the hot air out fast and silently. There are vents on the PCI slots, provids extra cooling to graphics card.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 460mm x (D) 490mm
- Front bezel Material:Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay: 3
- 3.5" drive bay (External): 1(use one 5.25 to 3.5 converter)
- 3.5" drive bay (Internal): 6
- Motherboard: ATX / M-ATX
- System Fan (Front): 120mm Blue LED Fan x 2 (1200RPM)
- System Fan (Top): 140mm Fan Hole x 1 (Fan not included)
- System Fan (Rear): 120mm Fan x 1 (1200RPM)
- I/O Ports: USB3.0 x 2 / e-SATA x1 / HD Audio
Only £234.99 inc VAT.
ORDER NOW
Lian Li PC-8FIR Aluminium Midi Tower Case - Red @ £249.99 inc VAT
The PC-8FI is equipped with large cooling fans, with low RPM, which still provide enough air flow to cool down the hardware adequately. The front two 120mm intakes red LED fan runs at 1200RPM. The rear 120mm exhaust fan just next to the CPU, it can remove the hot air out fast and silently. There are vents on the PCI slots, provids extra cooling to graphics card.
- System Fan (Front): 120mm Red LED Fan x 2 (1200RPM)
- System Fan (Rear): 120mm Red LED Fan x 1 (1200RPM)
Only £249.99 inc VAT.
ORDER NOW
Lian Li PC-V352B Aluminium Cube Case - Black @ £136.99 inc VAT
Lian Li designers combine modern functionality with simple lines and a classic simple theme. The external sections combine with hair line brushed anodized finishing with a metallic look to create the traditional theme expected from Lian Li. PC-V352 is designed for your living room, it can fit a standard Micro ATX system into this tiny chassis and a standard ATX P/S2 power supply, whilst retaining great thermal performance. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent, whilst also featuring Lian Li patented Anti-virbation HDD cage, which allow user to fit three 3.5" HDDs. It is easy to use, no tool required, simply using the special thrumb screw to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. PC-V352 equipped two 120mm intake fans, at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports x 2, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. Depending on your need, all I/O ports can be installed on the right or left side of the case, allow for easy access.
- Dimensions: (W) 280mm x (H) 275mm x (D) 400mm
- Front bezel Material: Aluminum
- 5.25" Drive Bay: 2
- 3.5" drive bays: 4
- Motherboard: Micro ATX / Mini ITX
- System Fan (Front): 120mm Fan x 2
- System Fan (Top): None
- System Fan (Rear): 80mm Fan x 1
- I/O Ports: USB3.0 x 2 / e-SATA x 1 / HD Audio / SD Card Reader
Only £136.99 inc VAT.
ORDER NOW
Lian Li PC-V352R Aluminium Cube Case - Red @ £174.99 inc VAT
Only £174.99 inc VAT.
ORDER NOW
Lian Li PC-X900B Full Tower Aluminium Case - Black @ £399.99 inc VAT
The TYR PC-X900 is the case which functionality and style converge. Open the side panel with the tool-less latch, HDD racks, 5 x120mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts. The PC-X900 has two-heat zones designed to provide a better thermal solution and helps tidy up internal space. The new internal layout has the motherboard on middle level, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. To install the power supply unit, just slide the power supply unit throguh the opening at the rear of the case, and there are room for 180mm long power supply. This case features Lian Li patented Anti-virbation HDD cage, which allow user to fit seven 3.5" HDDs. It is easy to use, no tools required, simply using the special thumb screws to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. There are three of 120mm blue LED fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
In the upper zone, there is a 120mm exhaust blue LED fan at the rear to draw the hot air out, and improve the air flow inside the chassis. In the lower zone, there is a 120mm exhaust blue LED fan at the rear to draw the hot air out, and improve the air flow inside the chassis.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports x 4, e-SATA, Audio supports HD Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 230mm x (H) 598mm x (D) 388mm
- Side Panel: Transparent Side Panel
- 3.5" drive bay: 8
- System Fan (Front): 120mm Blue LED Fan x 3
- System Fan (Rear): 120mm Blue LED Fan x 2
- I/O Ports: USB3.0 x 4 / e-SATA x 1 / HD Audio
Only £399.99 inc VAT.
ORDER NOW
Lian Li PC-X900R Full Tower Aluminium Case - Red @ £459.99 inc VAT
- 3.5" drive bay: 8
- System Fan (Front): 120mm Red LED Fan x 3
- System Fan (Rear): 120mm Red LED Fan x 2
Only £459.99 inc VAT.
ORDER NOW
Lian Li PC-Q06B Mini-ITX Aluminium Case / Test Bench - Black @ £64.99 inc VAT
PC-Q06 is a Mini-ITX TEST BENCH system, it supports standard Mini-ITX motherboards on the top, depending on your needs, it also supports ATX / M-ATX motherboard tray (Optional) for your system.
The clean shape of PC-Q06 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of PC-Q06 is to be as simple as possible, the exterior of the case is also the structure of the chassis. Multi-media port connectors follow international specification standards, with one connector for easy installation. The Chassis is made of 1.5mm aluminum alloy panel, The thick and solid chassis has no vibration problem. To reduce the size of the PC-Q06, the side panel are secured with screws, it also reduce the vibration, and lower the noise level. There are vent holes at the bottom and the rear panels, allowing air to enter to cool the system down. PC-Q06 supports a single 3.5" HDD, simply un-do the screw, ideal for easy HDD installation and services. The Hard Fits at the top of the chassis underneath the external motherboard risers.
- Dimensions: (W) 205mm x (H) 210mm x (D) 250mm
- 5.25" drive bay: 1
- 3.5" drive bay: 1
- Motherboard: Mini-ITX (Option: ATX / M-ATX)
- System Fan (Front):None
- System Fan (Rear): None
- I/O Ports: USB2.0 x 2 / HD Audio
Only £64.99 inc VAT.
ORDER NOW
Lian Li PC-Q06R Mini-ITX Aluminium Case / Test Bench - Red @ £74.99 inc VAT
- 3.5" drive bay: 1
Only £74.99 inc VAT.
ORDER NOW
Lian Li PC-8NWX Aluminium Midi Tower Case - Black @ £149.99 inc VAT
PC-8NWX has special safety features such as folded edges at strategic points to prevent sharp edges hurting users. PC-8NWX have very simple and functional thermal design, intake the cold air from the front, and exhaust the hot air at the rear. To make the system silent, and at the same time, to keep it cool, PC-8NWX features a 12cm fan, to move large amounts of air, whilst being quiet still. PC-8NWX features Lian Li patented Anti-virbation HDD cage, which allow user to fit three 3.5" HDD. It is easy to use, no tools required, simply using the special thumb screw to secure the anti-vibration rubber ring to the HDD, and slide the HDD into the cage. There is one 120mm exhaust fan at the rear of the chassis, which is silent and can move a good volume of air.
Multi-media port connectors follow international specification standards, with one connector for easy installation. New USB3.0 ports, e-SATA, Audio supports HD Audio or AC97 Audio. The dual design is for better compatibility options. All I/O ports on the top cover, allow for easy access, there is also a dust-free cover to protect these connectors.
- Dimensions: (W) 210mm x (H) 450mm x (D) 490mm
- 5.25" drive bay: 4
- 3.5" drive bay: 4
- System Fan (Front): 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / HD+AC97 Audio
Only £149.99 inc VAT.
ORDER NOW
Lian Li PC-Q08R USB3.0 Mini-ITX Case - Red @ £104.99 inc VAT
Mini-Q PC-Q08 is made in Taiwan, with the highest quality aluminum alloy panel. The Mini-Q PC-Q08 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q08 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q08 is to be as simple as possible, the exterior of the case is also the structure of the chassis. To ensure you can put everything together easily, Lian Li design team decided to use only standard PC component inside the Mini-Q PC-O08, standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics card.
- Dimensions: (W) 227mm x (H) 272mm x (D) 345mm
- 5.25" drive bay (External): 1
- Expansion Slot: 2
- Motherboard: Mini-ITX / Mini-DTX
- System Fan (Front): Black, Silver / 140mm Red LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Red LED Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio
- Maximum Video Card Size: 300mm
Only £104.99 inc VAT.
ORDER NOW
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Black @ £92.99 inc VAT
- Expansion Slot: 2
- System Fan (Front): Black, Silver / 140mm Blue LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Fan x 1
Only £92.99 inc VAT.
ORDER NOW
Lian Li PC-X2000F Aluminium Full-Tower Case - Black @ £554.99 inc VAT
The TYR PC-X2000F is the case which functionality and style converge.Open the side panel with the tool-less latch, HDD racks, 5 x140mm silent intake fans with filter, top mounted multi-media I/O ports, and the graphics card holder have been redesigned – because when it comes to your comfort, every detail counts. The PC-X2000F has two-heat zones design to have better thermal solution and tidy up internal space. The new internal layout has the motherboard on middle level, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. To install the power supply unit, just slide the power supply unit throguh the opening at the rear of the case. The fans are mounted with Lian Li’s anti-vibration fan mounting system; the rubber ring grommet absorbs the vibration, keeping the case silent. TYR PC-X2000F features Lian Li SAS hot swap HDD cage, which allow user to fit seven of 3.5" HDDs. It is easy to use, no tool required, there are aluminum handles for HDDs, allow user to install or remove HDD easier. There are three of 140mm fans at the front to bring the cold air into the system. The fans cover the whole motherboard, and they can remove the heat fast.
- Dimensions: (W) 240mm x (H) 695mm x (D) 442mm
- 3.5" drive bay (Internal): 7(SAS Hot Swap)
- Motherboard: E-ATX / ATX / Mirco-ATX
- System Fan (Front): 140mm Fan x 3
- System Fan (Rear): 140mm Fan x 2
- I/O Ports: USB3.0 x 4 / e-SATA x1 / HD Audio
Only £554.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
- 3.5" drive bay: 8
ORDER NOW
- 3.5" drive bay: 8
ORDER NOW
- 3.5" drive bay: 1
ORDER NOW
- 3.5" drive bay: 1
ORDER NOW
- 3.5" drive bay: 4
ORDER NOW
- Expansion Slot: 2
ORDER NOW
- Expansion Slot: 2
ORDER NOW
ORDER NOW
