Just wanted to ask about that, forgive my thread intrusionAWDFLASH.EXE M629B_11.BIN /py /sn /Wb /cd /cp /cc /CKS
Well I've updated the BIOS and still I cant use 4 sticks. Plus I couldn't get through to Abit tech support this morning.
As far as the memory goes, I tried running them at 2.2v, with the timings set to 5-5-5-18-T2. I also tried 5-5-5-15-T2. Neither setting worked.
Well whatever. I've got Windows installed now, and if worst comes to worst, I can order a new motherboard later in the year and install the extra RAM then. (Though I hope it doesn't come to that.)
Meanwhile I'm going to install programs until the tech line opens, and then I'll try getting through to them again.
Just wanted to ask about that, forgive my thread intrusionIs there any reason you use the /Wb option? Just when I downloaded a new BIOS ready for my IP35 Pro coming I noticed that you're recommended options for AwdFlash are different to what Abit have in their runme batch file. Just curious really if it's definetly needed and if it's safe to use, as I'm not sure what it does even with the screeny
not updating it gives you a recovery option though in the event of a failed flash so there is method in their madnessThey don't include a couple of switches they should tbh. The boot block is a small ROM segment that initialises the board and checks the bios is correct before it boots it. Really should be updated along with the new bios.
Nobody chooses to use itRE: Award bios, personally for repairs and general OC, using it has solved far more problems than it ever caused. Recently had a board that wouldn't recognise G0 chips without an updated bootblock. Over the years, failed flashes et al (excluding soldered bios boards 'persuaded' to bootblock recover, just hotswap em). Typically the initial bootblock checksum for the floppy call is intact, not that I'd use it given a choice.
so far abit have resisted doing so but still use socketed BIOS chips - their X38 mobos appear to be continuing in this.Its a hell of a lot easier to hotswap the chips, I wish they'd stop soldering them, even top end boards they've started soldering PLCC again![]()
As I said, if its socket mounted you have a choice. Hotswap and reflash, beg/buy a new chip, bribe someone with EEPROM burner or try recover.Nobody chooses to use itbut it often works to recover the BIOS from a failed flash.
Well I wish Asus would do likewise. Come on, how much is a PLCC socket mount compared to a £190 board?so far abit have resisted doing so but still use socketed BIOS chips - their X38 mobos appear to be continuing in this.
