- 2 Aug 2004
- Glasgow, Scotland
Ok here goes,
Everything is connected fine, i press power on the case , psu turns on , mobo fans turn on , then 2secs later it turns off.
Ive removed the battery for 5mins and put it back in on motherboard but still no progress. There isnt a jumper on the clear cmos on the motherboard. Hence went with battery option.
Now i took out the memory sticks to see if motherboard would beep to warn me about no memory etc etc, nothing. Its just the fans that turn on. I hear no beeps what so ever.
Im at a loss here.
Motherboard is MSI ZZA-G43
PSU OCZ ZT 550W `80 Pluz Bronze Modular
Memory : Crucual Ballistix Sport 8GB(2x4GB) DDR 3 PC3-12800C9 1600mhz Dual Channel Kit.
Ive not connected the 670gtx , or the ssd or 2tb hdd and dvdrom. As trying to find the fault.
Spent over 900 on this build from ocuk and i cant get it going
1st this has every happened to me, im experienced with building as well.
I dont know if its the motherboard ? or the PSU ? but the psu does turn on and gets the fans all going etc, then stops. Every other motherboard ive had beeps when you turn it on etc, im getting nothing at all from this one.
Really im at a loss.
Im at a loss here.
1st this has every happened to me, im experienced with building as well.I dont know if its the motherboard ? or the PSU ? but the psu does turn on and gets the fans all going etc, then stops. Every other motherboard ive had beeps when you turn it on etc, im getting nothing at all from this one.
