- 25 Oct 2022
- UK
Hi all,
Would be grateful for advice on my new build. PC will be used mostly for gaming but I'm not looking to go extreme.
1 X **B Grade** AMD Ryzen 7 5700X Eight Core 4.6GHz (Socket AM4) Processor - Retail - £269.99
1 X Asus Prime X570-P (AMD AM4) DDR4 X570 Chipset ATX Motherboard - £159.95
1 X Corsair Vengeance RGB PRO Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit (CMW16GX4M2Z3600C18) - £82.99
1 X Fractal Design Pop XL Silent Black Solid Full Tower Case - Black - £129.95
1 X Corsair RM Series RM650 650W '80 Plus Gold' Modular Power Supply (CP-9020194-UK) - £87.94
1 X Noctua NH-U12A High Performance CPU Cooler - 120mm - £95.00
Grand Total: £839.02
I have the following from my current PC that I'm looking to reuse: crucial CT480M500 SSD 500GB; Seagate 2TB HDD; MSI GTX 1060 6GB, although I may well upgrade these later (esp the GPU) when budget allows.
TIA
TIA
