Hello all,
Just to give you a bit of background info before reading, it's been about 4 years since I last built a system (Was using a dual core 5500+). So I need to just pick your wonderful brains in regards to a couple of questions which I have.
Okay, so.. I'm on a bit of a budget being a Dad, and I've decided to treat myself as my laptop is a bit pap for gaming.
I've opted to go for an AMD build, ordered a Gigabyte micro ATX motherboard running the A85x chipset. Being on a budget I'm going to use an APU for now, I was considering the A10-5800K (3.8ghz), however, I don't know wether just to plump the extra twenty squid and go for the new Richland 6800K (4.1ghz).
I'm sticking 8gb of 1833 DDR3 RAM in with it for now.
I'm going to bung a graphics card in a later date when I have a good payslip from doing overtime, so I know gaming performance won't be blistering running off the APU.
So.. A10-5800K, or A10-6800K?
Also, I'm putting a Corsair CX500 PSU in it.. Will this be sufficient for what I'm running? Going to have 3 case fans, only 1 hdd, dvd drive etc. Will that PSU cope when I add a graphics card in the future?
Sorry if I've not been very clear, it's been a while
Many thanks,
Ben
Many thanks,
Ben
bit tired.
