Hi, I am getting close to the build config I want but could do with some advice on a few things.
The configuration is going to be something like this:
- BenQ GL2760H 27 inch LED Monitor
- Zalman Z11 Plus
- Corsair 750W RM750 RM Series 80 PLUS Gold
- Gigabyte Z97X-Gaming 5
- Intel Intel Core i5 4670K
- Zalman Reserator 3 MAX Ultimate Liquid CPU Cooler
- Crucial 2x4GB DDR3 1866Mhz Tactical Tracer Orange/Blue
- Crucial 2x4GB DDR3 1866Mhz Tactical Tracer Red/Green
- MSI GeForce GTX 760 OC 4096MB
- Samsung 250GB SSD 840 EVO
- Hitachi DeskStar 1TB
- Asus 24x DVD±RW DRW-24F1ST SATA Black
- Asus Xonar DG 5.1 PCI
- Asus PCE-N15 300Mbps 802.11B/G/N
- Zalman Blue LED Keyboard and Mouse Set
- Venom Vibration Gaming Headset XT
- Thrustmaster GPX
- Budget is between £1000-£1500, would like to overclock it as best I can to something like 4.5Ghz - 5Ghz.
- Would the Power Supply be enough or should I pay a little extra for the Corsair 850W RM850 RM Series 80 PLUS Gold?
- Also what about the Cpu/Motherboard/Memory, would this be a good setup or should I look for an alternative?
- I can get the Avexir 2x4GB DDR3 which is 2400Mhz for slightly more, would I benefit at all with this?
- Also if the motherboard states for memory compatibility that the speed needs to be overclocked does this mean I can not run it at native speed?
For example:
1066Mhz
1333Mhz
1600Mhz
1866Mhz(OC)
2133Mhz(OC)
2400Mhz(OC)
2666Mhz(OC)
2800Mhz(OC)
3000Mhz(OC)
What speed would the Crucial 1866Mhz or Avexir 2400Mhz run at? Do I need to overclock the memory to reach its native speed or something?
- As this is my first intel build for nearly 4 years ago I am unsure also on which processor would be good for gaming, I like the looks of the i5-4670K but again advice needed please.
Could really do with advice for this build, many thanks in advance
- Zalman Z11 Plus
- Thrustmaster GPX
For example:
1066Mhz
1333Mhz
1600Mhz
1866Mhz(OC)
2133Mhz(OC)
2400Mhz(OC)
2666Mhz(OC)
2800Mhz(OC)
3000Mhz(OC)
