- 29 Nov 2011
Hi,
I am in the process of building a new PC and after searching around for the ideal motherboard, CPU, Graphics card etc. I have pretty much given up as I don't have much knowledge with PC's.
I currently have an old machine I built few years ago and i was thinking of salvaging some of the parts to use on the new build.
The current specs are:
Asus M3N78-VM motherboard
AMD Phenom x4 9550
Coolmaster CPU cooler
GeForce 8600GT
8GB OCZ DDR2 Ram
750W PSU
1TB 7200rpm HD
24" 1080p Samsung LCD TV/Monitor
I've been looking into buying a new Motherboard, CPU, GPU, Ram (DDR3) and case and using the HDD, PSU and the cooler from the old machine.
I will mainly be using the PC for video editing, mathematical modelling software (Matlab, Maple), internet and the occasional gaming. I have been looking at the AMD x6 CPU's (phenom 1055t, 1090t, FX 6100) as they seem to be a better choice for video editing but I have been advised that the Intel’s i5 2500K is a better CPU for the task.
Some members on another forum suggested going for the i5 2500K, Asus P8Z68-V/GEN3 and the GTX 560ti. I am happy with the CPU as I can get hold of one for under £150 but the Motherboard and the video card seems a little expensive. Can you make alternative suggestions? Is there a decent mobo and GPU for under £100? I have a budget of ~ £500 or $800.
Appreciate your time and help
AMD Phenom x4 9550
GeForce 8600GT
8GB OCZ DDR2 Ram
750W PSU
1TB 7200rpm HD
any advice?
