- 18 Feb 2009
What I ordered:
£174.99 x 1 - Samsung SM2494HS 23.6" Widescreen LCD Monitor (LS24KIVKBQEDC)
£166.99 x 1 - Zotac GeForce GTX 260 "55nm Maxcore" 896MB GDDR3 TV-OutDual DVI (PCI-Express) - Retail (288-OK101-000ZT)
£131.99 x 1 - Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail
£99.99 x 1 - Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
£83.47 x 1 - Antec 900-2 Nine Hundred Two Ultimate Gaming Case - Black (No PSU)
£79.99 x 1 - Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939)
£72.99 x 1 - Corsair HX 520W ATX2.2 Modular SLI Compliant Power Supply
£52.99 x 1 - Razer Lycosa Gaming Keyboard
£16.99 x 1 - Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
HD - Samsung HD322HJ SpinPoint F1 320GB 7200RPM SATA 3GB/s 16MB Cache OEM
RAM - OCZ Memory 4GB Kit (2x2048) Platinum Edition Dual Channel DDR2 PC2-8500 1066MHz CL 5-5-5-18 Memory Platinum XTC Heatspreader
Connected everything together, but when turned it on for the first time, it started up, then died down again (keeps doing that every time I turn off PSU from the back), then started up and stayed on, but no signal to the monitor. All fans working (Case, Graphics card, and CPU)
What I tried doing:
Made sure, the 24 pin and 8pin are connected (even tried 4 pin)
Taken Ram out (no beep, am I supposed to get it, like everyone says)
Tried 1 stick at a time (both)
Made sure graphics card is properly inserted int PCIe slot, made sure 2 PSU connecters (6pin each) are properly attached (although if the fans are working that shouldn't be the problem?)
Tried disconnecting all extra devices, but have to try that again, not sure if I got them all. Was getting tired by that time, so stopped experimenting.
One thing I think I've done wrong is when installing heatsink onto the mobo, first time it haven't fitted properly, so I lifted it up again (thermal paste included with Core 2 was spreaded), and put it back on. Then when the comp wasn't working I tried refitting it again. Is it essential that after applying thermal paste you don't keep lifting heatsink up from the motherboard? Whatever the case is, I'm going to buy some thermal paste and refit the CPU, then pull the mobo out of the case and try to turn it on with just PSU, ram and Graphics card.
Any suggestions or help would be appreciated.
What I tried doing:
