Hi,
I have just purchased the following new build:
YOUR BASKET
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - OEM (CM8064801548435) £289.99
1 x MSI X99A SLI Krait Edition Intel X99 (Socket 2011) DDR4 ATX Motherboard £189.95
1 x Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV256HDGL-00000) £139.99
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x SuperFlower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - White £102.95
1 x Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler (CW-9060021-WW) £101.99
1 x Kingston Fury Black 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/16) £99.95
Total : £1,044.80 (includes shipping : Ex.VAT).
This will be accompanied by my existing Asus 970 Strix GPU and an exteral 500gb HDD.
My request is for some help on the cooling set up.
I will have the following to place:
Corsair 240mm AIO CPU cooler
2x 140mm fans (with the case)
1X 200mm fan (with the case)
1x EK Water Blocks EK-Vardar F1-120 (1150rpm)
Potentially 1 further 140mm fan from my old Antec 300 case.
Whilst the actual fans may change over time, I am really hoping for some input on the best configuration on intake and exhaust. The CPU will be Overclocked to around 4.2 gig.
Rather than spend a lot of time getting it wrong, I felt it would be better to see what more experienced builders thought on a suitable configuration.
Many thanks in advance.
YOUR BASKET
