New build - display problem
9 Oct 2009
Leeds,UK
I have just built a new rig for my mum, and installed her old version of XP - run all the updates etc.
Problem is im getting serious lag when dragging windows around. The same thing that happens on soggy old machines that are almost out of memory.
Apart from this it is lightening quick. What could be causing it?
Sorry was a fresh install of windows?
Could try running hd tune or hd tach to check for hard drive performance and possibly mem test the ram, just to rule any possible hardware problems.
OK i updated the ATI Drivers and its much better.
Yes its a brand new install. Complete new build.
I will run some hardware tests just to make sure but it seems ok, Ive been on W7 for a while now so I can't remember how smooth XP should be. I have a feeling im going to have to start over when she decides to get W7 anyway.
