Just installed my new set up:
Intel i5 @ 3.6Ghz with Corsair H50 Cooler
Asus P7P55D Evo Intel P55 (Socket 1156) DDR3
Geil Ultra Series 4GB (2x2GB) PC3-17000 2133MHz Dual Channel Kit
Everything seems to be working fine thankfully, does this screenshot seem about right:
Started it off at 3.6Ghz but will attempt to try higher later on.
ps. I know my hdd is rubbish, SSD coming soon hopefully.
Win 7 Ultimate 64 installed all the drivers, the only thing I installed was the latest gfx card drivers for the 260 GTX. However, can anyone identify this unknown device and how I can either install the correct software, or as I think, possibly disable something in the bios...
Probably best to set your RAM manually to no more than 1.65v in the bios. You don't want to fry your cpu!
