I just built a new pc this morning, nforce 680i LT motherboard, 260 216core gtx,
4 gb ram, 500gb hd, aftermarket cooler, 850watt Powercool psu, E400 core 2 duo 3.0ghz.
Plugged it all up.
doesnt start up, the motherboard has a blue light in the corner above ram but thats normal apparently, ive taken everything out apart from cpu, 1 stick of and harddrive to try to start it but still it doesnt turn on!, ive read the motherboard manual step by step, could this be due to a faulty motherboard? some of the capasitors are slightly bent, but bent them back straight, the mb has a 8pin 12v which i got 2 x 4 pins but works well apparently but no luck.
any info would be greatly appreciated.
thanks
karl
Plugged it all up.
thanks
karl
