New Build failing to boot - constant RED CPU light - gigabyts mobo
4 Aug 2019
Hi Everyone really looking for some assistance please. (Hope this is the right place to post)
I bought a whole new setup listed below:
Mobo - Gigabyte x570 Aorus Ultra
Cpu - AMD Ryzen 7 3800x
RAM - vengeance pro 2×8GB 3200MHz
PSU - Corsair HX750
SSD - NVMe - Aorus 512GB
The graphic card is second hand but confirmed working - GTX1070 Zotac (temp graphic card)
Installation went smooth - but when I power on the PC everything lights up and all my fans spin including the ones on the GPU. My mouse and keyboard also light up. However when I switch it on there is a red light that comes on immediately on the motherboard indicating that thers is a problem with the CPU.
There is also no display on the monitor and no beeps (no speaker on this mobo or POST on this mobo - silly)
Sadly I have no other components to swap any of the ones out to test.
I have-
Made sure all the power cables are connected properly.
8pin on mobo is connected to the 8pin on psu
4pin on mobo is connected below 8pin on psu (4+4 socket)
Gpu is connected using 6+2 and connected to a solid 8pin on psu
Everything else has been removed for now.
Removed the CPU fan and CPU - no bent pins.
CPU is plugged into correct port on mobo not CPU_OPT
RAM - have I placed into different slots. But manual says to use A2 and B2 first which is their current position. I have also tried using only on ram stick.
Removed CMOS battery - also tried using the screwdriver method as suggested in the manual.
Have removed the GPU and tried using onboard graphics.
Flashing BIOS has been suggested excpt I cant get a display so not sure how to even do that?
Is there any other ideas please... such a bummer. I have built my own PC before but never been this unlucky.
TIA
http://imgur.com/TXWelYp
Are you sure the CPU cooler is seated correctly and making contact? Is there any dirt in the CPU socket? Do you have a piezo-electric buzzer installed and if so is it beeping?
Sadly I have no piezo-electric buzzer but have ordered one off Amazon which should arrive tomorrow. I'm sure that would help a lot to narrow it down.
As for the cooler it's well seated the clips can only go one one way. And flipping over the wraith prizm clip is not an easy job does feel a bit extreme. As for dirt etc this is a new board so cant see where that would have come from. I unpacked it and started the build so there wasnt time for dust build up etc.
How long have you left it in that state? My Gigabyte board did take quite some time to boot for the first time.
For future debug, note there's no onboard graphics with Ryzen non-G chips.
As mentioned above some new motherboards seem to have several cycles before they boot happily the first time.
Try clearing CMOS proper: power off at the wall (or unplug, but then you're not grounding the PC). Remove CMOS battery. Short CLRTC pins for 10 seconds.
Then try powering up with one RAM stick.
Edit: also try this outside the case to rule out shorts.
I have rebuilt outside the box with only attaching the minimum to the board.
Removed the CMOS battery then used a screwdriver to short the CLR_CMOS pins. Inserted one RAM stick and started it all up leaving it to run for about 5-10mins. I can see the graphic card fans spin and stop and then start again. I'm guessing this is showing that it's in a boot loop?
Still no display or boot. I can see my monitor pick up something on the HDMI slot as it switches to it automatically but then goes to sleep mode.
The red cpu light however is still on during all of this.
Arise, @GIGA-Man, I summon thee! :)
Sorry been away for a little while and was banned by the family from using digital devices :-)
Okay, it does sound like the CPU could be an issue here. You can use Q Flash plus to make sure it's not a BIOS issue, the details should be on page 6 of your motherboard manual but I have also put them below. If this doesn't work then I would advise raising a return for the CPU and board to be tested.
1-3 Using Q-Flash Plus
A. Before you use Q-Flash Plus, follow the steps below in sequence: 1. From GIGABYTE's website, download the latest compressed BIOS update file that matches your motherboard model. 2. Uncompress the downloaded BIOS file, save it to your USB flash drive, and rename it to GIGABYTE.bin. Note: The USB flash drive must use the FAT32/16 file system. 3. Insert the USB flash drive into the white USB port on the back panel. 4. Connect the power cables to the 12V power connector (connect either one if there are two) and main power connector.
B. Using Q-Flash Plus Press the Q-Flash Plus button and the system will automatically search and match the BIOS file in the USB flash drive on the white USB port. The QFLED and the Q-Flash Plus button on the rear panel will flash during the BIOS matching and flashing process. Wait for 2-3 minutes and the QFLED will stop flashing when the BIOS flashing is complete.
• Before using the Q-Flash Plus function, make sure that your system is off (S5 shutdown state). • If your motherboard has a BIOS switch and a SB switch, reset them to their default settings. (Default setting for the BIOS switch: Boot from the main BIOS; default setting for the SB switch: Dual BIOS) • After the main BIOS is flashed, the system will reboot automatically and then DualBIOS™ will continue to update the backup BIOS. After completion, the system will reboot again and boot from the main BIOS. • Q-Flash Plus will update the main BIOS only if run without the CPU installed. The system will
Thanks for the response guys.
I have since RMA'd the motherboard - which was tested and confirmed to be DoA.
However received my new board today and after setting everything up it all boots perfectly - so YAY for that.. Sadly after a couple seconds of boot the CPU fan stops spinning. I checked the BIOS and it seems that the temparature its reading for the cpu is minus 55 degress (-55)
I did a BIOS update to the latest available - F4i if i am correct. still no luck
I then plugged the cpu fan into a sys_fan to ensure it doesnt over heat and installed windows.
Using speedfan - and placing the fan back into cpu_fan doesnt show anything.
Please let me know if there are some alternatives... really hoping this isnt another RMA..
I have taken pictures just no idea how to share them here.
thanks for the help as always
Hello Corne,
The BIOS is reporting -55 ? Is it just the stock cooler for the CPU you are using?
Hi GIGA-Man
Correct using the stock cooler - AMD Wraith Prism.
I have RMA'd the board again. So hopefully 3rd time lucky..
Thanks for the response!
Oh... So sorry you are getting this issue, it's very strange to get two boards with issues back to back. Let me know how you get on and if I can offer any help.
I’m having the same issue on Aorus x570 With the Ryzen 9. -55 degrees when I can get to the bios, otherwise it either only powers on for a fraction of a second or (more often) stays on with a CPU error light.
For me it appears to be linked to the DisplayPort connector on my Radeon 5700XT for some reason. When I try booting from complete power off, using only hdmi, it’s fine. I’m not sure what the problem is there :/
This is odd, what card are you using? \
@Corne did the RMA get this resolved for you?
