- 24 Apr 2009
Hi all. I recently purchased new pc parts from Overclockers as my old PC was over the hill. Here are the parts I bought...
I also bought a Kolink Enclave 600W 80 plus gold modular PSU.
With the bare minimum connected to the mobo, 24 pin connector and 8 pin 12V connector, the case fans and cooler fan come on at power on but the water cooler does not light and PC seems dead, nothing on screen and won't post. Water cooler is connected to PUMP header and its associated fan is connected to FAN header. I wasn't able to find a power LED on the mobo to show it's actually getting power, but the ethernet port lights up with RJ45 connected so it's getting some description of power. Just wondering if the cooler was faulty would it stop the machine turning on? Thanks
Intel Core i7-13700F (Raptor Lake) Socket LGA1700 Processor - Retail | £299.99 | 1 | £299.99 |
Asus Prime B760-Plus D4 (LGA 1700) DDR4 ATX Motherboard | £108.33 | 1 | £108.33 |
Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey | £49.99 | 1 | £49.99 |
Kolink Umbra Void AIO 120mm Performance ARGB CPU Water Cooler | £48.29 | 1 | £48.29 |
