New build - Final thoughts!
13 Sep 2011
N.Ireland
Well I've finally picked my rig, and I can't wait to order it in 3 weeks time when I get payed.
Can you all confirm that the below is all compatable, is good for gaming and into the future ie; future proof?
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN
Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-368-GI
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-247-AS
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-AN
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS
Zalman Z9 Plus Tower Case with Fan Controller - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-ZA
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=HD-248-SE
Samsung SH-S222AL/RSMS 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CD-102-SA
What I also would like to know is opinons on wether I can change anything here for a better deal? Is there anything I'm missing and would you buy this rig yourself?
And last but not least I will be getting my monitor somewere else.
I'm getting a 22" Viewsonic VX2268WM, 3D 120Hz, Wide, Black/Silver, LCD, VGA/DVi, 20000:1, 300cdm2, 1680x1050, 3ms
Thanks very much people.
system in the whole should be fine, i'm guessing it's a Stulid spec list tbh lol
if it was me, i wouldn't go for the zalman case, but thats my taste, everything else is totally fine :)
There's some black ram that's the same speed etc for less.
If you can live with the colour?
you're going to want a 3rd party cooler if you want to oc, the intel does allow for 4-4.5ghz from what I've read but the 3rd party ones will give you better temps. in that case the fins on the ram will interfer with the cooler.
