new build help NO POST/NOTHING
16 Aug 2006
Stoke
Hey guys,
Built up my new system, powers up ok now with the different mobo ECS p965 one, and no matter what i seem to do the system will not post and will not display anything on the screen..
other components
geil 2gb pc6400 value i think
c2d 4300
x1950 pro
Where should i start to trouble shooot, i tried without ram in, one stick in etc.
hmmm, i had similar prob, worst scenario was gfx card had gone, everything sounded ok, no error beeps on start up
id try your gfx card in another PC, see if it works
Yeah it should beep indicating a graphics card problem if there is no graphics card installed you woulda thought.
If you get no beeps with the gfx in then it might be the processor that is faulty if it isn't the motherboard.
Given that its an ECS board, make sure the CMOS jumper is in the 'run' position as these sometimes ship with it set to clear. Also, try clearing the CMOS if you haven't already.
Good luck.
thanks for the advice.
I will double check the jumper for a start.
I definitely getting no beeps what soever
replaced the power supply, replaced motherboard, and i am still not posting.. something tells me it was not the mobo after all!
damn damn damn damn damn
