hi ..i have this ..(pic)http://i840.photobucket.com/albums/zz323/luckyjohn99/Untitled.jpg
Your 100MB boot manager partition is really on the wrong drive.
If you'd installed Windows without the HDD connected it would be on the SSD which is the best place for it.
but windows is on ssd isnt it
right so what do i do now then
Was it a pre-built PC? or did you build and install Windows yourself?
i have built my new comp and using it now..
built it tnite my first build
