new build help - power supply
16 Aug 2006
Stoke
Hi I have a power supply Hiper 580w that is just over 4 months old, i have used it in my new build and for the life of me I cannot get it to post, removing all components one by one and just trying memory with cpu.
The motherboard P5N-e has a green light that comes on but as soon as i press the power button it will power up for less than 2 seconds then switch its self off again....
so am I missing something or am I buying a new power supply
Hiper go boom boom.
For some strange reason, this past month there have been numerous reports of the 580w Hiper's borking. Sounds like yours has joined the club.
oh my, but it does put power thru the mobo the green light comes on, it just wont POST it wont even power on for more than 2 seconds.. this also happened on an old mobo that i thought was borked... :(
would already have done it buddy if i have one, I just spend 621 quid, I don't mind getting another PSU as long as i know it will cure it
Why not buy a moderately cheap one, retain the receipt, test out your pc, if it works, then RMA the PSU, if it doesn't, well, then you've got a problem.
yeah this is true, I will be going back to the retail store i bought it from, I can't find my receipt though
Replaced power supply, same problem happens... when i remove the cpu the power supply will boot up the machine, but of course it doesn't post, with the CPU in place it will power for less than 2 secs before switching off...
What have i missed? Don't tell me my new 4300 is borked
Dont mean to be total noob, but its first time i ever had a problem with a build and its really troubling me.
Ensure the CPU fan is in the correct motherboard header. Most systems will not boot if the CPU fan is disconnected. This sounds like your problem.
You might also try clearing the CMOS - on the offchance the system is trying to boot at some specification other than that rated for the chip. Resetting the CMOS resets the board to failsafe defaults.
Also try building the board out of the case - on the anti static bag it came with - this will ensure the board is not shorting against the case.
cheers guys,
I have built it on a anti static bag, unfortunately I had the same problem. I haven't tried clearing the CMOS, its a new board so i wouldn't have thought it would make that much difference. I will give that a go in a min.
I have managed to get it to power up with the CPU and HFS in place, but it has happened on two separate occasions. Then it didn't post anyway... :(
I am going to ring technical support in the morning, and then return what ever is causing the problem i hope it can be turned around real quick.
Wish i had some more ideas mate.
I have resurrected a system by just leaving it off over night after the PSU had tripped its overvoltage protection, allowing it to reset.
I think your Hiper is just knackered, but that is just based on the fact they have been going boom recently.
Can you try the PSU with the old build?
What sort of components are in the new build.
Scratch that you have tried the bare board so you are well under the Wattage budget... hmm
I now have a jeantech artic 600w in place so the PSU isn't the problem as exactly the same thing as happened, hence why i am so upset
