New build help required please?
I would do a complete system back up and store it onto an external drive. Do this once all your drivers, programs and other personal settings are all tweaked to the way you like it. Once your happy, do a full backup. This will ensure if your install ever becomes corrupt and you can't boot into Windows, you just tap F8 on start up, select the repair computer option and choose, restore from image. It doesn't take very long at all and is a lot better than reinstalling because it means you don't need to install drivers, programs, antivirus... setup browser settings, favourites, folders, icons, colour schemes... the little things that take hours.
Finally getting somewhere, had a few distractions over the last couple of days.
Thanks 'Buchanan0204' used your advice.
Put windows/office & a couple of progs I use every day on SSD & everything else on the D drive which is the 1TB HDD re-used from the old system, took me awhile to work out how to re-map everything to the D drive, my docs/pics/music/videos ect.
Once installed everything & done settings ect the way I like it, done a windows back-up to the D drive (Not ideal but will have to do until I have saved enough for the external solution I'd like) & created a Windows 7 Pro 64-bit restore DVD.
Is this ok or have I missed something? I am thinking, if anything goes wrong with SSD then can wipe/erase & re-install everything using the restore DVD & back-up file? (In any case would come straight here if anything did go wrong before doing anything, lol)
Got a few issues I'd like help and advice for, will address them in my next post to keep the advice here & any new advice seperate but in the same thread.
1 of the issues I am having are that I have now read that I should off installed the latest bios for my motherboard & installed the latest firmware for the SSD drive.
I am confused a little as everything is working fine, I think?
Should I upgade the motherboard bios to the latest? the latest is 1.40, I am currently on 1.10, (there is a 1.30 inbetween) but the IRS latest driver suggests you install the 1.30 motherboard bios. Don't know what to do, should I stay with my 1.10 bios or upgrade to 1.30 or 1.40?
I also understand there is a firmware update for my SSD from the current 2.06 to 2.08, have no clue what to do about this, should I upgrade or not? will I benefit? need to read/learn a lot more about SSD.
In CPU-Z it shows my cpu as 1596.5MHz Multiplier=16 Bus Speed= 99.8MHz, I thought this was 3.30GHz stock? confused = yes
The memory bought says DRAM=665.2MHz FSB:DRAM 1:5 9/9/9/24/1T
SPD Says max memory bandwidth is PC3-10700(667MHZ) but the memory says PC3-12800 1600MHz, confused = yes again.
Do I need to change a few settings in the bios to correct these problems?
Also lastly should I disable the on-board VGA & just use my HD5850?
Worked out that the memory is running @ 1333 or 1.333 so not far off the 1600 rated speed, I know I need to change something in the bios to get this to run @ the rated 1600 speed, but not sure what? more worried about the cpu @ 1600 & not the rated 3300.
The CPU has speed step enabled, if you download CPU-Z and also Prime95, you will see the speed increase to its correct value when the CPU is actually doing something.
The memory speed selection is in the BIOS, its under OC tweaker then you will see DRAM configuration, theres a pull down box you can use to select the speed.
windows has even more updates, will do all these & then re-start to bios for the mem change, thanks Stulid.
Shall I disreguard my cpu concerns than? just worried as last cpu (intel core duo E6600) throttled the cpu as cooler deteriorated over time & it was mega overheating, don't want this happening to my shiny new set-up, lol
I will d/l prime95 & run it, just to learn about it as want to oc
restarted & changed the mem in the bios, now says 798.4 which is 1600, but the rest is 9/11/11/29/1T should this not be 9/9/9/24/1T?
why do you need ahci stulid? im very interested :)
I would like to know that too as I am learning, as everybody says ahci not ide but don't mention why? I understand it's not 1 on 1 here and people give their time for free.
I also know why people just state quick answers as most of the time, as the op just wants a simple straight forward solution on what to do & don't care about why, as long as it works.
tysm stulid, will absorb the full answer in the morning!
do u have any answer to my other queries/problems above please?
Are you the only helper here stulid? big thanks, as I know many more from my research are here, why don't you people contribute on this thread?
Does my oldschool username (that needs changing but I don't know if I can or how) put you off?
i did my ssd installation on IDE, does that mean it is going to fail or something? so i need to reinstall with AHCI?
Native Command Queuing (NCQ) is a technology designed to increase performance of SATA hard disks under certain conditions by allowing the individual hard disk to internally optimize the order in which received read and write commands are executed. This can reduce the amount of unnecessary drive head movement, resulting in increased performance (and slightly decreased wear of the drive) for workloads where multiple simultaneous read/write requests are outstanding
Well timings make little difference to memory perofrmance, so you can leave it and not worry about it.
Or you can change them manually in the BIOS and see what happens.
You can download BIOS 1.4 from the ASrock website, theres even a Windows version that you simply double click the .exe file and let it rip, theres also a guide on how to do if your concerned, I did the Windows version and it was totally painless.
