New build help SLI 2x 970 GTX
30 Mar 2007
Essex
Guys I'm about to put a new build together , going back to PC gaming after a 7 year break .
So since I've been out of the loop so to speak GPU's have come a long way . I'm looking at getting back to some BAttlefield and it seems an SLI rigg makes the most of this .
I can buy 2x 970 GTX for £400 I'm looking to play on a 24 inch monitor and maybe even in 4K .
Is there anything else out there that's worth considering ?
Thanks .
Is this what's referred to as the Titan ?
No. It's the successor to the GTX 980. But the same type of Nvidia cooler is also used on Titans, which might be why you associate it with those?
Oh , any prices ?
Not yet. From what Nvidia have said, this should result in options between £325-400. And 1070 should be about twice as fast a 970, and with 8GB memory not 3.5/4 GB.
Take with pinch of salt as it's guesswork. But definitely wait.
