- 27 Jan 2012
- The king of the north!
Doing it now saves money in the longer run and can be done on almost budget really.
But you are speccing something that is contrary to what the OP has asked for and telling him he should get it because of the future. He clearly predominantly plays arma / milsim based games and has asked us to help him spec a new build to play those as his current requirements with his monitor. A 1060 will run any game faultlessly at 720/1080p that he is currently using. And even if he upgrades to 1440p it won't be a problem. So i really don't see why you are trying to push his budget up by £136-£236 for something that he wont be able to even use 100% of in the games he plays.
OP this is what i would personally recommend as an arma player myself.
My basket at Overclockers UK:
- 1 x Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail= £248.99
- 1 x Cooler Master Hyper 212 Evo CPU Cooler= £24.95
- 1 x Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit (HX424C15FB2K2/16)= £98.99
- 1 x WD Blue 1TB 7200rpm SATA 6Gb/s 64MB Cache HDD - OEM (WD10EZEX)= £47.99
- 1 x BitFenix Neos ATX Tower Black/Black Window= £35.99
- 1 x Corsair VS 550W '80 Plus' Power Supply (CP-9020097-UK)= £47.99
- 1 x Zotac GeForce GTX 1060 Mini 6144MB GDDR5 PCI-Express Graphics Card= £239.99
- 1 x Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £145.99
- 1 x Samsung SM961 Polaris 256GB M.2-2280 PCI-e 3.0 x 4 NVMe Solid State Drive= £119.99
Total: £1,023.17
(includes shipping: £12.30)
The reason i chose the more expensive nvme ssd is because it will really help a lot having arma installed on that, you will know what i am talking about when i refer to the lag when you ADS with a x34lrr scope or Zoom in far away and you for some reason stop to a halt, thats because the drive is struggling to stream the parts in required to render that area. ssds help a lot with this and a lot less fps dips occur thanks to fast ssds.
You will get a good performance boost from overclocking the cpu as well as those style games really like a high clock speed, it really isn't a difficult thing to do just slightly unsettling the first time you start to tinker, but that fast goes away. And you can always ask on here, there are lots of people willing to give excellent advice.
