- 20 May 2006
ok so i have the new rig up and running but need a little help as i have the gigabyte P35C DS3R and the GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit and i have read that you have to adjust the memory voltage on the mother board to match the voltage of the memory .
so on the memory there is a sticker that says the voltage of the memory is 2.1v
so how do i do this from here it says i can go up 0.1,0.2 etc but in the bios it says the memory voltage is on normal and pc is running good so far but i aint tried a game so do i need to change the voltage or not ? and on the motherboard it says its Rev 2
Thanks for your help
Thanks
