Hi,
Just build up a system with one of OCUK i5 bundles and the H50 Corsair cooler. I have attached one intake to front, one exhaust to the roof and the corsair fan exhausting to the rear. Does this configuration sound ok? The instructions say to use fan as intake but I have read elsewhere that exhaust is fine.
What kind of temps should I be expecting as normal? I really haven't a clue on this sorry.
I have been having random freezes where I return from a trip downstairs and have a black screen - have to reboot to get it going again. Any ideas of things to check?
I just hope I have the thing built properly. I put the H50 pins into the top CPU_FAN header and then SYS_FAN2 for the pump power. Other fans are going into the SYS_FAN headers. I noticed one section called PCH_FAN. Do I need something in it?
I think i will have loads more questions so will keep this thread for them all!
Thanks in advance
Thanks in advance
