Hi,
Im looking for some advice regarding the parts listed, which im thinking of buying - Primary use will be gaming, WoW, COD, NFS Shift etc. I was thinking 2x120mm at the front, 2x120 for Push-Pull set up on the H-50 and the 140mm for the roof - will I need this many? I would like the PC to run as cool as possible, but considering im not overclocking the PC (yet) will it require this many? with this many fans will I also need some sort of fan controller?
Im trying to go for RAID-0 for quicker loading times and writing times, will I also need a RAID Controller for this?
Im also trying to get to the £1000 mark, is there anyway I can loose the £90 without sacrificing performance?
I also dont need an OS, Monitor or any peripherals.
Excuse the silly questions, Im new to all this.
Thanks.
Thanks.
