I made a thread not long ago, I'm going to order the parts within the next few days so i want to see what i should change with it. I've never overclocked so would anyone suggest me getting a pre-overclocked bundle? or just overclock it myself by researching?
Atm I'm thinking if i get a pre-overclocked set:
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle
- with the 8gb option, looking at the motherboard options there doesn't seem to be any major difference - could anyone explain to me why the other boards are more expensive?
The build will be mostly for gaming, video editing (HD) and other design aspects. The main problem for me is I have trouble working out what power supply i should use, if i use the overclocked bundle along with the 6870 what would i need?
I have a budget of around £800 as I'm buying a new monitor outside of the budget. I'm already sorted for peripherals, hard drives and OS. I was tempted to go for the 2600k but i can't justify the extra £100 for a little, if any, increase in performance. As for the case, many have recommended the Xigmatek (sp?) White Knight, but i don't know much about it and even though its supposed to be solid the low price puts me off.
If someone could piece the best possible build for what i need, it would be appreciated. Going slightly over budget isn't a worry either, just nothing over the top
