Hey all, looking for a bit of help with a build. Couple of years ago I bought a pre-built PC as my first gaming PC which has done the job, but I'm looking to upgrade as I have an itch to get in to either streaming or making videos. I consider myself quite clued up on technology but it's more knowing what fits and works well with each component. I have chosen everything and configured a build that is ideal for my budget but I would really appreciate some advice on if it would be suitable and/or compatible.
Here is what I have configured;
OcUK Tech Labs AMD Ryzen Midi Tower Gaming PC Configurator
Processor: AMD Ryzen 5 2600X Six Core/Twelve Thread 4.25GHz Processor (MPK)
Motherboard: ASUS TUF B450-PLUS GAMING (Socket AM4) DDR4 ATX Motherboard
CPU Cooler: Raijintek Aidos Black CPU Cooler for Ryzen
Memory: Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-21300C16 2666MHz Dual Channel Kit - Black (CMK16GX4M2A26
Case: Raijintek Arcadia II Midi-Tower Gaming Case - Black Window
Soundcard: ASUS Xonar SE 5.1 PCI-E gaming sound card with 192kHz/24-bit Hi-Res Audio
Network Adapter: ASUS PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter
Solid State Drive 1: Kingston A400 480GB SATA 6Gb/s 2.5" Solid State Hard Drive - (SA400S37/480G)
Mechanical Hard Drive 1: Seagate BarraCuda 2TB 7200RPM 256MB Cache HDD - *System Stock*
Graphics: Gigabyte GeForce GTX 1650 OC 4096MB GDDR5 PCI-Express Graphics Card
Power Supply: Kolink KL-500M 500W 80 Plus Bronze Modular Power Supply
Any help would be greatly appreciated!
Thank you
Thank you
