New build issue
6 Jun 2008
Stevenage
Hi all
Have just built some his first pc and ran into a problem. Pc ran fine for a day and now it won't switch on at all. Have stripped it right back and can't find what's the fault.
The mobo is a asus tuf gaming a620m-plus wifi
PSU is MSI MAG A750GL 750W 80 Plus Gold ATX 3.0 PCIE5 Modular Power Supply
The mobo doesn't have a light indicator at all.so unsure if it's getting power. If I press the bios flashback button this lights up which to me indicates power but how can I be sure that I get the right part replaced. Don't have another PSU or mobo to be able to test either way which is a pain!
Any advice appreciated
If the PC is 100% dead with no response to the power button then I'd say most likely:
- Bad case switch.
- Bad PSU.
- Bad motherboard.
Something like loose cables is a possibility, if it was moved.
That's what I thought, just not sure now to proceed. Do I rma PSU/mobo etc. got them from ocuk but not had to do this before so not sure what happens if their also not actually faulty as I got no way to verify one way or the other so feel kinda stuck
You can turn on a PSU without anything plugged in, though that's not a 100% reliable, because it can turn on and run and still be faulty.
My guess is that OCUK will just tell you to send them both back and then they'll test and confirm.
Was all the parts new and bought at the same time?
Do you have another PSU you could test with at all?
As its a modular PSU have you checked all the connections at the PSU side rather than the motherboard side?
The fact it worked for a day rules out bios imo.
I would pull the board out put it in the motherboard box and test there to rule out a short.
You probably going to send it back anyway
Just done the mobo flashback which appears to have completed as it stopped flashing but again it won't boot at all.
Attempted a jump start using power pins in case it's the power switch and nothing still
Just confused that if it's the psu surely I couldn't do the flashback to the bios?
And if it's the mobo why did it also appear to let me flash the bios!?
Maybe because its not drawing a high amount of power (GPU\CPU)
its a strange issue considering it was working for a few days but now is not.
Do you have a multimeter? you can check the PSU using 1 of these and a paperclip
For example, Corsair PSU test
Full spec is a Ryzen 7600
Sapphire Radeon RX 7600 XT Gaming OC 16GB GDDR6 PCI-Express Graphics Card
Kingston NV2 1TB M.2 2280 NVMe Solid State Drive (SNV2S/1000G)
Asus TUF Gaming A620M-PLUS WIFI (Socket AM5) DDR5 Micro ATX Motherboard
Kolink Observatory MX Mesh ARGB Midi Tower Case - White
Crucial Pro DDR5 RAM 32GB Kit (2x16GB) 6000MHz CL36, Overclocking Gaming Memory
Got nothing to be able to test with so ordered a new mobo last night from another supplier which is coming today just so I can test and hopefully rule one of these out!
I would have thought if it was a dead CPU etc then it would try and boot etc. I don't even get a power light when pressing the power button. Absolutely dead, no activity at all which makes me think mobo or PSU
Let us know how you get on
