- 28 Oct 2011
Board: Gigabyte X870E X3D.
Quick summary.
This error isn't listed in MOBO debug list. although it seems to be memory related according to the info I can find. I've tried the RAM stick hokey cokey but to no avail. RAM is -
www.overclockers.co.uk
GPU seems alive (been tested in old PC anyway, it's definitely been seated correcty), PSU came from old PC, - AIO and fans start, but now the AIO screen isn't lighting up, fitted and already pre-plugged in MOBO fans x5 (Antec Flux Pro) don't start up. The back fan which doesn't fit into pre-installed header does start up.
Quick summary.
Crucial Pro OC 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit
Order Crucial Pro OC 32GB (2x16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit now online and benefit from fast delivery.
