- 1 Jan 2008
Hi all and in advance thanks for any help.
I recently bought a Q6600 + Ballistic DDR2 Ram + Pk5 Premium Mobo all from overclockers to replace my old mobo/cpu.
Everything was going well for a few days, I put it all together no problems, booted up and was playing cs and browsing the web no problem.
Then on sunday I went downstairs to get a drink, came back up and my comp had turned itself off and now wont turn itself back on again!
I have been pulling my hair out trying to get her back to life but have had no luck. I understand that it could be any number of things and the best thing to do would let an expert have a look at it but I have tried a couple of things,
The mobo does have its green led light on when connected to the power supply and also the feature where a red led comes on when a pci card is incorrectly installed still works, but it just won't start.
When the on button is pressed the power supply make a tiny 'zzz' noise and the fan on it moves a fraction, but nothing else.
I tested if the power supply would start manually by jumping the green cable with a black one on the main power supply plug, this resulted in the power supply starting. This makes me think its a mobo problem, which is annoying as its my new one
What are my options here? What shall i do, get system checked out by a pro? Return the mobo? What else could i try myself?
Thanks for any hints
Matt
- New wall plug
- Different Power Lead
- Check if the on switch works on the case
- Remove all PCI cards
- Take mobo out of case and attempt to start it out of the case
- Remove the RAM/CPU from mobo and attemp to start it
.What are my options here? What shall i do, get system checked out by a pro? Return the mobo? What else could i try myself?
Matt
