New Build, Need some help.
18 Nov 2005
Ok here is a proposed build.
Now for a few points:
  • I have a 670 which I plan to keep till next year
    A 2 month old 800w PSU
    Decent Monitors
    CD drive
    Asus Sound card
Another few points, im in no way looking to overclock and haven't done for years but I would like a nice stable system that's future proof. I've been running my i7 920 for a while now and its starting to lag behind slightly.
Any suggestions please, I'm all ears, cheers.
On another note, looking at some of the boards and compatibility with DDR3, I see some say 2133(OC). Does this mean I need to OC or what exactly?
YOUR BASKET
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - OEM (CM8063301292702) £425.99
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £169.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9) **SPECIAL** £139.99
1 x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black (CC650DW) £139.94
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
Total : £1,139.95 (includes shipping : £11.75).
It is possible to get a hex core CPU for a bit more money.
You will need to set the RAM to XMP profile to set it up to the right speed as it defaults to 1600MHz.
Thats for the build Stulid, heres another I've just looked at...
Samsung 840 EVO 250GB 2.5 inch Basic SATA Solid State Drive
Gigabyte GA-X79-UD3 Intel X79 Socket 2011 Motherboard
Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - OEM
Patriot Viper "Black Mamba" Generation 3 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PV316G160C9QK)
Corsair H100i
Western Digital Caviar Blue 1TB
Again, good spec, one thing I failed to mention was the UD3 will likely need a BIOS flash to recognise the 4820K/4930K, the CPU 's are supported with one of the later BIOS files, see if the place you purchase from will update the board for you.
