New Build potential problems
16 Mar 2012
Newcastle
Just about to buy everything and just wondered if i've missed anything obvious that could cause problems.
Spec
i5 2500k
Western Digital Caviar Blue 500GB SATAIII
Gigabyte Z77-D3H Intel Z77
OCZ Agility 3 60gb
Bit Fenix Shinobi mid
Corsair Vengeance Blue 4GB (2x2GB)
OCZ ZS Series 550W '80 Plus Bronze' Power Supply
Windows 7 OEM
Asus HD 6850
Thanks for the help
Dan
To be honest its 50/50 at the minute, i probably wont be overclocking purely because i dont know how... so do I go 3570k?
Also what are the intel 4000 graphics like ?
I might have to wait a few weeks to get my 6850
Don't worry i'm convinced!
Okay same price too so ill go for that... what about the motherboard? i know i could spend more but im on a budget and it seems like it does what i need.
Also im assuming that the PSU is sufficient for everything?
Right, makes sense, even though ill not be fitting aftermarket cooler right off the bat.
Cheers for the help lads
All ordered! Heeded your advice and went with the 3570k and Crucial SSD instead of the OCZ!
Again, cheers for the input, much appreciated!
