28 Oct 2011 at 20:15 #21 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare cant tell, so there was no random stand-off underneath the PCB?
28 Oct 2011 at 20:19 #22 GTO656 GTO656 Soldato OP Joined 29 Aug 2011 Posts 3,068 Location UK stulid said: cant tell, so there was no random stand-off underneath the PCB? Click to expand... Heres a pic I took few days ago: Some of the standoffs are lower than others(I to use both of them from the screws to fit) I'll try and take a pic now to show you what its like
28 Oct 2011 at 20:30 #23 GTO656 GTO656 Soldato OP Joined 29 Aug 2011 Posts 3,068 Location UK Just uploaded the pics here it is: Should I put the PCIs back in?
28 Oct 2011 at 20:34 #24 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Put them back in. Restart, enter the BIOS and load default values and install the OS/drivers/updates.
28 Oct 2011 at 20:37 #25 GTO656 GTO656 Soldato OP Joined 29 Aug 2011 Posts 3,068 Location UK stulid said: Put them back in. Restart, enter the BIOS and load default values and install the OS/drivers/updates. Click to expand... Brilliant thxs dude!!!
