As the hack means running through the xp setup agaid then you'd probably be as well just starting again from scratch and this time WRITE THE PASSWORD DOWN.....
What WinXP CD did you use to build it with ? You can slipstream a password into a build CD so its automatically entered. If this is what happened then you'll get the same problem again.
