New build Psu problems!
25 Feb 2012
I have recently decided to make my first gaming rig, so far i have obtained the
PSU - Corsair CX600
MOBO - Asrock p67 pro3 SE
Case - Coolermaster Elite 335u
I have connected them all up mounting ect connected all the case headers and the atx power connectors but no power from psu????
I have noticed that when i connect the 24 pin in whilst the psu is on (INO BAD IDEA) it spins for a millisecond along with my case dan and the power led's
i have no idea why its not running
ANY IDEAS?
You need to have all your parts insatlled. CPU etc.
Also i doubt weather it will work any more as you have probley killed it by connecting the PSU to the M/B while the PSU was powered.
Well nothing's going to work without a CPU and RAM but as already stated I wouldn't want to put money on things still being alive after they were plugged in with the power on :(
mm i suppose i shall but a cheap cpu and ram to test just to get up and running then upgrade form there i just thought that the power switch on the case would do something like make the psu spin ect.. but if it needs a cpu /ram to do that would explain it ..
But i thought you can start up without ram but it would just beep constantly
Regards
