Mobo - Asus M4A78LT-M LE AMD 760G (Socket AM3) DDR3 Motherboard
CPU - AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz
Whats the "125W Edition" mean specifically? just use's less power from the psu?
Ram - Geil Black Dragon 6GB (3x2GB) DDR3 PC3-10666C9 1333MHz Triple Channel
Im assuming this is compatible with my Mobo.
Graphics -Either the ATI HD4850 or the Geforce 470
Not sure which one to go with anyone able to convince me either way? looking at around £2-230 Pounds budget
HDD - Samsung SpinPoint F2 EcoGreen 1.5TB SATA-II 32MB Cache
Not sure on the hdd either im looking for a big 1tb+ hdd fast for windows/games etc and looking at around 50-70 pounds maximum!
I have the rest ready and waiting but i am just a bit miffed as to whether i will need a new power supply at the moment i have a 500Watt Ultra Xconnect Modular power supply and wonder whether this will be good enough to power the machine ofc i am also looking at overclocking the cpu to 4000mhz which im guessing will require more power also? So will I need a new PSU?
I am also looking at doin the buying in two parts Mobo/Cpu/Ram/HDD first then Gfx Card and possibly PSU if i need to upgrade it.
Will my 500Watt PSU be sufficient to run
8800 GTX Geforce
6ish USB Slots being used also
Any help and recommendations will be helpfull will be greatful :> thanks a lot!
Also my Budget is around 600-650 pounds for CPU/Mobo/Gfx/Ram/HDD & Maybe a PSU!
8800 GTX Geforce
