Hi,
I'm planning on building a new budget gaming system and I'd like some advice on some of the components I'm thinking of using. Here's what I've got so far:
CPU: AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz
Graphics Card: HIS Radeon R7 260X iPower IceQ X2 Turbo 2048MB GDDR5 PCI-Express Graphics Card
Motherboard: ASRock 990FX Extreme3 AMD 990FX (Socket AM3+) DDR3 ATX Motherboard
Memory: Patriot Viper "Sapphire Blue" 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit
I plan to use a 500W dual rail PSU and an SSD as well. I don't currently play many modern games but I'd like the system to be future proofed, i.e. would be perfectly capable of handling things like WoW, LoL, BF4 etc.
The things I'd like opinions on are:
1. Will there be any bottlenecks with the above spec, e.g. between CPU and graphics card or ram.
2. The RAM listed above is XMP compliant, although I'm using an AMD board with an AMD processor - is this likely to cause any problems?
3. Is the mobo I've chosen going to be up to the job of supporting the 8 core AMD processor, and allow me room for future overclocking?
4. Any other problems I might encounter with the above setup!
I'm not a hardware expert and haven't build a system in a few years so any help is greatly appreciated
Thanks!
Thanks!
