The Build Is:
Akasa 500watt Paxpower
Sapphire ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card Sapphire
AMD Phenom II X2 Dual Core 545 3.00GHz (Socket AM3)
OCZ Gold Edition 4GB (2x2GB) PC2-6400C5 Dual Channel Series (OCZ2G8004GK)
Asus M4A77D AMD 770 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard
Samsung SpinPoint F3 500GB SATA-II 16MB Cache
Sony Optiarc AD-5240S 24x DVD±RW SATA ReWriter
Hey,
Just built a new system... Upon installing the New OS (windows 7 x64 - legit) i noticed the res was awful low even for install ie (640x480) but ignored and continued but the system blue screened when expanding files... i did a second check of settings and all that fluff but all seemed fine.
I tried to install again but i took 3 attemps before windows was to install without blue screening - later to find it was to be "bad pool header" ?!? Am not sure what this is and a quick google doesnt really narrow it down.
However after getting to windows desktop... naturall i wanted to set the Res higher. Properties>etc>etc only to find it was fixed at 640X480 and to go no higher ??? it also says it is connected to the HD5770 via VGA ? when it is conected via DVI.
I figured i would try to install drivers for the card... upon which it Bluescreened on the web browser, after a restart i was able to get the drivers but upon clicking install i got an error saying it was not possable?!?
I closed down before i got another bluescreen then triple checked and swapped ram slots (as in my experience most BSOD happen with regards to ram).
After another restart i noticed Windows7 was loading with the old default loading bar.. rather than the 4 coloured windows coming together!
So i decided to do a computer index score thing... everything came back with a fair mark except the Graphics on a 1.0 ?!
I have a HD5770 (although not with me) and that clears the Index with a 7.9 without drivers.
So is there an ovious issue with regards to the graphics leading to BSOD...
I would much appresiate the help.
Many thanks.
Hey,
Many thanks.
