Hi I am having some trouble with my new build. The problem is that at intermittent times my PC will freeze up completely, the mouse and keyboard do not respond and any animations on the monitor simply freeze. I am left with no other option but to cold reboot my system.
It seems to be worse when I try and run my RAM at the rated 1600 mhz so I am left with running it at the mobo default of 400mhz with 9-9-9-24 timings, apart from the voltage which has to be manually changed to 1.9 volts (the recommended operating voltage) to get it to even boot up.
I have tested both RAM modules separately using memtest and both were fine after 3 passes each with no errors, however when I try testing both modules at the same time the system crashes and reboots.
I have the RAM in the recommended dual channel slots and have even tried shifting from one bank to another with the problem persisting.
Could this be a PSU problem ? I have used my old Jeantech 405 watt PSU and was worried it may not be enough.
The rest of my system is as follows :
AMD Phenom II 955 Black @ stock speeds
4 GB OCZ 3P13334GK Platinum Edition
ASUS m4a785td-v evo (latest bios revision v2002)
1 x CD/DVD RW drive
1 x SATA HDD
1 x Nvidia Geforce 7600 GT (being upgraded soon !)
1 x USB wireless reciever
Any help help in ironing out this problem would be much appreciated.
1 x CD/DVD RW drive
1 x SATA HDD
better get it sorted quick smart then
