Hi All,
So I am in the process of speccing out my new build - based currently around an i7 3770k and radeon 7950 card. I am looking to put it in the massive case Xigmatek Elysium on the basis I have a whole bunch of hard drives, will most likely add another GPU and want to go watercooling.
I was originally thinking I will chuck in a H100i for now and be done with it until I want to upgrade the cooling, at which point I will replace that. However, I am now thinking I will put either a kit or custom loop in, to cool the CPU (will be overclocking) and also up to 2 gpu's (and who knows - SSD too? lol).
What I want to know is, will something like the
EK-KIT H3O 360 HFX High Performance Watercooling Kit
or
XSPC RayStorm 750 RX360 WaterCooling Kit
be suitable? Ideally I want to spend no more than £225 or so at this point, but I need the system to be able to be added to at a later date - ie another 360 rad, another resevoir and GPU blocks, without needing to replace the pump.
I am also after a seperate tube style resevoir.
Will the above kits do what I need, or should I go purely custom, and if so, can you help spec what I would need, right down to tubing / barbs etc?
Hope you can help
Thanks
or
Hope you can help
Thanks
