- 9 Nov 2004
- West Midlands
Hi all,
I've just had all my bits and pieces delivered from OcUK for my new build. I have got a AMD Phenom II 955 Black Edition CPU.
Firstly I am not really looking to overclock this at the moment however I probably will have a go at some point in the future.
So my question is, do I stick with the stock HSF which does look pretty good or do I go and fit an Arctic Freezer 64 Pro (which was originaly for a 939 but seems it will fit all the latest sockets as well) which I have knocking around?
This cooler was intended for my last build, but the stock HSF was that good I never really bothered to fit it, that was also with an overclock from 2Ghz - 2.5Ghz on an Opteron 146.
So initially my thinking is the stock HSF will be more than enough for this processor or should I just go ahead and fit the Freezer Pro?
Thanks
Stu
Thanks
Stu
