Hello. Have finally received a motherboard to go with the rest of my parts today, but the PC wont post.
Took it out of the case and placed it on the box to ensure it wasn't a shorting issue and still the same.
Tried a single stick (in the manual suggested slot) and nothing.
Tried my old PSU and no change.
I assume I don’t need a gpu to simply post, although realise i wont be able to see anything.
The power button on the mobo is on, but pressing it does nothing.
I also tried a different battery, without any change.
Spec per below:
AMD Ryzen 3600
MSI X570 Unify
Team Group 8Pack Edition 32GB (2x16GB)
Seasonic Focus GX750
Sabrent M.2
noctua nh12 cooler
everything else I disconnected to rule out any other faulty components.
I am thinking perhaps it’s the CPU. I bought it a while ago (new) but was in its box. When I took it out some pins were bent so very slowly and using a razor blade got them all straight. The CPU went into the socket with extremely low force so assume all was well.
Apologies for the formatting mess, typing on a tablet. Any help would be appreciated.
Spec per below:
AMD Ryzen 3600
MSI X570 Unify
Sabrent M.2
noctua nh12 cooler
