Edit: The mobo, Ram and CPU just come back from giga. The Mobo pins were repaired & apparently the other parts were tested on the board. The cpu+cooler were still attached to the board when it arrived, so i left them & put the pc together again.
Now when i press the power button the LED's turn on for literally a second (if that), then there is no sign of life.....none whatsoever.
Any ideas? tried with 1 stack of ram, resetting cmos, taking the parts that are not req out (i.e gfx card).
Hi guys,
Today i built the following:
CPU Intel Core i5-4440 3.1GHz Quad-Core
Motherboard Gigabyte GA-B85M-D2V Micro ATX LGA1150
Memory Corsair Vengeance 4GB (1 x 4GB) DDR3-1600
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card MSI Radeon R9 270X 2GB TWIN FROZR
Case Cooler Master K380 ATX Mid Tower
Power Supply Corsair 500W ATX12V
Optical Drive Lite-On iHAS124-14 DVD/CD Writer
Monitor Hannspree HE247DPB 23.6"
After firing it up I was faced with 1 very big problem. The LEDs on the pc turn on (but flicker), after 15sec or so the PC sounds like It is going to start up, but shuts down completely. My monitor doesn't even get a signal
I have browsed many forums, googled etc and tried:
As well as a few other things....but nope, exact same problem.
Pics:
All wired:
http://tinypic.com/view.php?pic=2w512km&s=8#.VINqWTGsVdo
http://tinypic.com/view.php?pic=idt2l5&s=8#.VINqcTGsVdq
Connectors + front Panel:
http://tinypic.com/view.php?pic=1567m2r&s=8#.VINqdjGsVdo
http://tinypic.com/view.php?pic=2eqc26w&s=8#.VINqeTGsVdo
CPU + Socket
http://tinypic.com/view.php?pic=2ihargy&s=8#.VINqijGsVdo
http://tinypic.com/view.php?pic=2m4vs&s=8#.VINqjzGsVdo
CPU slotted in
http://tinypic.com/view.php?pic=5njafa&s=8#.VINqlTGsVdo
Back:
http://tinypic.com/view.php?pic=2dm7foh&s=8#.VINqojGsVdo
http://tinypic.com/view.php?pic=io0t41&s=8#.VINqpjGsVdo
Please help as this is a Xmas present that I'm building...
Hi guys,
- remounting cpu/making sure it is placed correctly.
- Starting with 1 stack of ram
- Checking RAM is inserted properly
- Starting the PC with only the mobo, cpu,PSU and Ram
- Re-inserting the front panel connectors
- Starting the PC with only the power SW connected
- Making sure the board is mounted on risers
Pics:
All wired:
CPU + Socket
CPU slotted in
Back:
