New Build - Wrong Case =(
If you RMA something you normally pay to send the item to OcUK, but this isnt a normal RMA. I would contact customer services, i cant see how they can expect you to pay to return an item that is a different one to the one your ordered.
I dont think I would, but the case I want isnt in stock, and with some sticker work etc on this case (specially over the AMD logo lol), I will like it more than any of the others tbh. I dont have time to wait ages for them to be restocked, and wait for delivery so...
Meh, the AMD logo will be glued over, one thing that im a little puzzled about is, according to the manual, I seem to need a screwdriver, on the video for the K62 other cases it makes quite a point of the fact that you dont.
Does it have thumb screws for the PCI E back panel covers? Thats the only thing i can think off that would require a screw driver :confused:
You'll need a screwdriver for things like screwing the motherboard to the standoffs.
Not everything it tool-less.
Well, its definately different in some way, as the video said definately that you can pull the case fans out and put them back without a screwdriver in the other ones, but on this case they are screwed in
Only for the 5.25" drive bays I'm guessing? ;)
Hmm true, well, I can still build it in the case cant I? Pretty sure all it is is an AMD logo on the case
Or will it have different connectors or anything...
True they probably wont let me do that, but seriously its not my fault, I need it now for some work, and I cant send it back
Yes you can 100% build the PC in the case, there is no different connectors just because it has "AMD" on the side doesn't mean you cant build a rig with a Intel processor in it :)
I think he's on about having to pay to send something back that was sent to you in error, You shouldn't have to when its not your mistake.
Yeah thought that at the time (January) but I didn't get anything back. Had to pay to send second one back too when it died after a week. Don't have much luck with motherboards :p
Sorry if I was ambiguous, others picked up on what I meant, though. I didn't understand why you had to pay for shipping. :)
Think it's me just havin a slow day :D
if you have to pay for postage back to OCUK and/or cant be bothered sending it back, i would just leave it as it is(AMD logo), whose actually going to know what system you have inside?
and it might even be a good thing if you decide to go AMD in the future :)
Just an update on this, I decided to keep the case in the end, and I can say that the case I purchased which turned out to be incorrect can no longer be seen on the website, hopefully in a while I will just grab the K62 Blue Window and I can just replace the panels on the one I have lol as I now have my new rig up and running nicely!
