- 17 Oct 2002
- Stoke-on-Trent
Looking to move to a new case. I currently have a Fractal R2.
Pros
I like the dust filters, easy to clean
Plenty of HDD space
Cons
Can't get a Window side panel
A little cramped with my Phanteks and GTX580
I am looking for something around the same size but with more space inside to perhaps have another 580. I need room to put 5 HDD's which can be cooled easily and room for the huge Phanteks to fit without being cramped.
Also something with cable management behind the motherboard tray.
I like the look of the Silverstone TemJin TJ07B-W BigTower Windowed Case but from the image shots it looks as though it lacks in cable management.
Pros
Plenty of HDD space
Cons
I think we have a winner, bigger than I wanted, but fits 95% of what I want. Did you need to get any extension cables for power?
