New Case and System build
14 May 2008
Hi,
I've found myself getting into gaming more and updated my HTPC to give me this fix for a few years now has come the time for me to get make something a little better.
The partner said as-long as she can't see it. So the case will be stored in a BESTA(IKEA) unit and when it is in use the door would be open and the back frame of the unit would no longer be there.
The maximum dimensions of the enclosure are:
H50 D35 W55
This is my only worry as most D are more but I could move the case around but then air flow may be an issue?
I will probably look to run the system on air or CPU water cooled, along with 2 SSD and 1 GPU. The parts I haven't looked into yet and my HTPC will be retiring to my mothers for her to use for basic browsing so could salvage.
Current HTPC
Processor AMD A8-3850 APU with Radeon(tm) HD Graphics
Video Card AMD Radeon HD 6550D
Memory 4.0 GB
Storage 2x2TB 1xSSD 250GB
PSU Corsair 350W~
current case SST-ML06B Silverstone
Looking for something mid ranged that can handle all battle net games and most RTS/MMO budget is not an issue but I'm looking for something that I could upgrade slightly later on if it needed it. I also don't mind waiting to see what the new gen is like but there is always something new so could be waiting for ages. This will be connected to a 40" Samsung 3D TV but this will be replaced with a monitor later down the line.
