New case for M ATX build.
25 May 2013
Kent.
Looking for opinions on a few cases, I don't really want RGB but the 6 fans was the selling point on the 1st one especially in this heat. Not fussed about tempered glass, normal side panel is fine and up to £50 as I'm looking for cheap and cheerful.
GPU is a Zotac 1660 and Seasonic S12II with flat cables so don't need huge cable management space.
1. https://www.overclockers.co.uk/b-gr...-argb-midi-tower-case-black-bg-ca-07r-kk.html
May be missing fans as it's B grade but I can pick up new ones.
2. https://www.overclockers.co.uk/b-gr...m-midi-tower-case-black-bg-cas-klk-01625.html
Same as above really, less fans but cleaner look without RGB.
3. https://www.overclockers.co.uk/b-gr...-midi-tower-case-black-mesh-bg-ca-081-kk.html
All pretty similar and never had a Kolink case so looking for opinions. I know MATX in a mid tower leaves room but I'm fine with that.
Kolinks cases are fine. You can tell they have been built to a budget. If you're okay with that then I'd say they are very good value.
I've built in a few kolinks cases, so speaking from first hand experience
I'll look at the Lian Li ty, deffo won't need 6 but they're free so...
You're running a pretty low powered system with an M-ATX board, you might as well enjoy the benefits of an M-ATX case and the A3 is a lovely bit of kit.
While it doesn't come with fans, any HSF you bung in there will offer ample airflow when paired with the other components you've listed, especially if you're using an AiO as when top mounted it'll exhaust heat out of the roof.
These aren't terrible at the moment if you'd rather go new and want case fans included:
My basket at OcUK:
Total: £94.88 (includes delivery: £0.00)​
I've built in both and they're spot on for the price, the XT-M3 especially and is actually my personal case (albeit in white), it's an amazing bit of kit and feels much more premium than you'd think £50 would get you.
I've ordered earlier, the Kolink Stronghold Prism, even cheaper on deals and offers than B Grade.
I really wanted a fan controller tbh so that seems pretty good to get.
